Steering Noise - Non third gen
Old Mar 8, 2001 | 02:30 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
My friend's 87 pontiac bonneville makes a big whining noise when he turns the steering wheel left or right. We were pretty sure it was the power steering pump so we replaced that yesterday, but the problem is still there. The whining noise gets worse the more you turn. After we put the new pump in, added new fluid, let the car run for a while and then checked the fluid it was all foamy. He has no fluid leak and the steering is not any harder to turn then it was when there was no problem. Any idea what it might be?? Could it be the steering gearbox? thanks for any help
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops
Run a best of 16.7 @85mph before gears, slp headers on its way
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Old Mar 8, 2001 | 07:06 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
The noise is usually caused by either a bad pump or air in the system.
The same goes for foamy fluid.
Let it sit for a little while (to burp the air out of the system) and make sure its full, check for the noise again.
Have you driven it around yet??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Mar 12, 2001 | 07:19 PM
Car: 88 IROC
Transmission: auto
Yeah, it still does the same thing. He got it taken to a shop and they said its the pulley that's making that noise. They're gonna get a new pulley and put it on and see. The car is still in the shop. How can a pulley be making all that noise?? i'm curious to find out. Thanks,
Old Mar 12, 2001 | 07:25 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
I have seen a pulley make a wierd noise before, the pulley was plastic and it had a split in it.
Made a real weird sound.
That was only once, and I've never seen it again.
Let us know what the result is.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
Old Mar 12, 2001 | 07:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Keep checking back on the fluid. Often, when you first fill the system up, the bleeding process will foam up the fluid. Turn the car off, let the foam all settle back down to fluid, and refill the reservoir and re-bleed it. Keep doing that until it stays full with no foam.
If all seems to be OK until you lock the wheel against the stop and then when you let it back off the stop you get a huge belch of foamy fluid coming out the top of the pump, then you have a leak in the return side of the system, allowing air in. That will keep the fluid foamed up and low all the time even with a good pump, and may not leak enough fluid out to really be noticeable as a problem.
ICON Motorsports
theshackle
Sep 17, 2020 08:26 AM
Fronzizzle
Mar 18, 2019 08:29 PM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
