Rebuilt Engine Oil Pressure
Old Apr 26, 2004 | 12:01 PM
BigBadJap's Avatar
Car: 1989 GMC Jimmy Fullsize
Engine: 5.7L TBI (LO5)
Hi. I have about 7000miles on my rebuilt 350tbi and have noticed that the oil pressure seems to have come down quite a bit since brand new.
Brand new idle: 55 psi
Brand new highway: ~60+ psi
Hot idle: 30psi
Hot Highway: 45psi
I believe that 30/45 is well within the normal range for oil pressure, but what concerns me is that it's only been 11000km for it to drop from 55/60+ down to 30/45.
I've got a regular oil pump, not high volume and moly rings...
Does this seem normal for a rebuilt??
Old Apr 26, 2004 | 04:13 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Well, I am not quite sure of the drop you are having but I rebuilt my motor in January. After it was rebuilt, the car would idle at 15 PSI and anywhere between 30 to 45 PSI under load. After three months and around 1000 miles later it is still the same. I know this won't really help you but I figured I would post for comparison.
Old Apr 26, 2004 | 04:15 PM
Benm109's Avatar
Engine: 305 TBI
Sorry, I forgot. I rebuilt my 305, I didn't notice you had a 350 till I reread your post.
Old Apr 26, 2004 | 08:44 PM
BigBadJap's Avatar
You'd think the 305/350 would run similar oil pressures.
I was just thinking that I might still be running 5 30 oil and it's getting pretty warm here now... Maybe I should change it out then worry about it.
Old Apr 27, 2004 | 07:50 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
As the engine breaks in there is a normal drop in oil pressure. Spec is 30psi @3000 rpm.
Old Apr 27, 2004 | 08:02 AM
ede's Avatar
ede
or 10PSI per 1000 RPM
Old Apr 27, 2004 | 10:55 AM
BigBadJap's Avatar
Thanks guys. You've put my mind at ease.
Old Apr 27, 2004 | 01:20 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yea but only to 3k
backtothe80s
Sep 5, 2015 12:39 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
ChevyZ71
Aug 13, 2015 07:30 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
