coolant bypass trick question
Old Apr 27, 2004 | 06:41 AM
gifman's Avatar
Car: 91 Formula
Went to try the coolant bypass trick on my 91 305 TPI and found that the coolant bypass hose is routed different then shown in the tech articles on this site.
It looks like the hose comes out of the throttle body and goes back into the manifold base - instead of in one side of the TB and out the other.
Can this trick be done on a 91 305 ?
gifman
Old Apr 27, 2004 | 10:03 AM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
Yea I did it on my 92, 91 should be the same. All I did was pull both hoses off the t/b and hose clamped them on a short piece of copper pipe, been good the last three years.
Old Apr 28, 2004 | 11:12 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I did the same thing on my 91 305 TPI, and carried it over to my SuperRam setup on my 383. I started to use one hose from the manifold to the diverter valve, but I need to keep the factory formed hard U-turn hose so I just used a "hose mender" to connect them together.
Bstrang6
Sep 8, 2015 04:29 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
TheExaminer
Aug 26, 2015 04:59 PM
redmaroz
Aug 16, 2015 11:40 PM
