fuel pump
Car: 89 Trans Am
Engine: 305 TBI
fuel pump
Wuts up guys. Does anyone have an easy explanation on how to change the fuel pump / remove the fuel tank on an 89 Trans Am 305 tbi. Also, the fuel pump i got is a "master". Is that good enough to work on a stock car or is it garbage.
Thanks guys
Chris
Thanks guys
Chris
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Drop thew panhard rod, drop the rear, drop the exhaust & heat shields, drop the tank, remove sender & swap pump. Reverse procedure. Never heard of "Master". I would not trust a "no name" pump, considering the consquences of it's failure.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
