Can I make an 0.015 head gasket work?
Heads have been surface milled. Unshrouding the combustion chamber increased the overall cc to about 67. To improve quench and keep compression ratios up, I have an 0.015 Felpro gasket.
Can this gasket work on my high mileage block? Anyone else run this gasket on a used, undecked block? Any problems I can avoid?
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I'm guessing you're talking about the Fel-pro 1094? I just bought two of them to use on my motor, but I had the blocked mill'd and the heads are brand new.
For the guys that need to link to see it here it is:
http://store.summitracing.com/partde...art=FPP%2D1094
They look like good gaskets.
Here's another post on it https://www.thirdgen.org/techbb2/sho...hlight=fpp1094
Some good points by Vadar and Damon
Yet another post
Thanks for the reminder though I keep on remembering once I get away from the PC I need to look up that gasket on here.
Yet another post
Transmission: 4L80E/4L80E
For the 305 I had new heads and used block. I used aluminum paint just to be sure I got a seal to the block (spray Coppercoat will be fine, too).
I used steel shim non-coated head gaskets on the 396 with used, unresurfaced heads and block. Sprayed with Copercoat prior to installation.
No problems with gasket leakage on either engine.
1992 Trans Am
May 10, 2023 07:19 PM
