Setting Total Timing....Help!
Old Mar 14, 2001 | 01:54 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
What is the "proper" procedure for setting total timing?? I have the timing tape and know how to install it...now I just need to know the proper way to set the total timing!!
Old Mar 14, 2001 | 01:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I didn't know there was a "total timing" possible to set on the TPI motors... i thought all you could set was a base timing. I mean, there's no mechanical and vacuum advances, right? Just the slight bit of mech in the distributor itself, and the computer handles the rest?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 14, 2001 | 02:00 PM
<font face="Verdana, Arial" size="2">Originally posted by TomP:
I didn't know there was a "total timing" possible to set on the TPI motors... </font>
My mistake...ignore the user name! I HAD tpi and swapped to carb!!
Old Mar 14, 2001 | 04:12 PM
82camaro's Avatar
Car: 82 camaro SC
total timing is base timing plus any advance that occurs(computer or distributer).
Vacuum advance only works at part throttle(not at idle of full throttle--it helps mileage) so I always unhook it to find total timing. Hold the engine at about 3000 rpm and check the timing(all of the advance should occur by then in a stock or mild engine). Mine likes 38 degrees total. Your distributer has a certain amount of advance 'built in'. That amount you cannot change without modifying the distibuter. You can adjust how fast the advance occurs with springs and weights. To increase total advance, turn the distributer and adjust the base timing up.
example
10 degrees base +25 advance gives you 35 total timing.
add 2 degrees to the base to make it twelve add 25 from the dist. and you end up with 37 total.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
customblackbird
Aug 15, 2021 10:16 PM
Grant2k
Jul 10, 2018 04:01 PM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
Dialed_In
Aug 20, 2015 01:45 PM
