383 Rod Clearance?
Old Mar 14, 2001 | 10:30 PM
Changa2's Avatar
383 Rod Clearance?
What do you guys recommend for a 'Minimum' Rod Bolt clearance between the Pan Rail and the bottom of the cylinder.
I'm on my 2nd time around and Paranoia has taken a grip. I was told .060" was the target but after the fact it became .060" Maximum. (This came from a local race oriented machine shop that I would consider a good source).
It just strikes me that an honest .040-.045" should be safe!
Agree, Disagree or just your Opinion?
Old Mar 14, 2001 | 10:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I've usually considered .050" the target... some people will run one with .030", but that seems a bit risky to me.
ICON Motorsports
Old Mar 15, 2001 | 12:27 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I think anything around than .035 or more is fine. That is what is piston to head clearance normally is and i think that should allow for any movement at the bottom also.
mrbird
Oct 20, 2015 03:43 AM
91 SrS
Oct 7, 2015 04:32 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
JSDaddy189
Sep 26, 2015 03:50 PM
