Jumpy in 2nd gear
Old Apr 30, 2004 | 10:29 AM
92birdie's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1 V6
Transmission: 5 Spd. Manual
Jumpy in 2nd gear
Ok when entering second gear, esspecially when first taking off, the car jumps violently till i hit third gear.
No other gears give me problems.
any one have any ideas?
thanks
1992
V6, 5 speed
Old May 1, 2004 | 12:11 AM
92birdie's Avatar
Engine: 3.1 V6
any one have ideas?
Old May 1, 2004 | 11:40 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Bad TCC lockup solenoid? But that wouldn't explain why the problem doesn't carry over to 3rd or 4th gear.
So does it feel like a drivetrain problem? Like a bucking or a shuddering?
Old May 1, 2004 | 11:54 PM
92birdie's Avatar
Engine: 3.1 V6
I do not know what u mean, all I can say is the shaking is bad enough it has lossended some of the interior parts
It only happens when accelerating straight from 2nd, once I rev about 2000 rpms or so it goes away
no other problems
Old May 2, 2004 | 06:26 PM
Nixon1's Avatar
Does it seem to happen mainly when accelerating at really low rpms? Low rpms accelerating means heavy load....which sounds like a misfire to me, most likely in the ignition system.
But you still haven't mentioned whether it feels like an engine problem or a drivetrain problem. Is the car itself just...JERKING, or does it feel like the problem is coming from the engine? Or to put it another way.... If you let off the gas when its happening, does it stop? If you give it more gas, does it get worse until the rpms get higher or you hit another gear?
Old May 2, 2004 | 08:08 PM
92birdie's Avatar
Engine: 3.1 V6
yes to accelerting at low RPM's
Yes to it lets off when I let off
thanks for ur help
Old May 2, 2004 | 08:22 PM
Nixon1's Avatar
No problem. Check your spark plugs, plugwires, and distributor cap and rotor first. Those are the cheapest.
Old May 2, 2004 | 08:51 PM
RebelTillDeath3's Avatar
Car: 92 Camaro
My car was doing that, but one of the wires were off the cap.
Had a truck in at work today doing the exact same thing, it shook whenever under load. The problem was one of the coil packs.
Old May 3, 2004 | 12:08 PM
Rivven87's Avatar
Car: 87 SC
Engine: 2.8 MPFI
Could be fuel, too.
A lot of low-RPM bucking is caused by that. Mine will do it in any gear around 1200-1600 whenever my MAF decides to cut out and it starts getting too much or too little fuel.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
TrevinE
Sep 14, 2015 03:20 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
