RPM Variation @ Idle & Acceleration
Old Apr 30, 2004 | 11:23 AM
HoustonL98's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 5.7TPI
Transmission: TH700R4
The RPM of the engine goes up and down regardless of being at idle or under acceleration. Engine is very healthy and has OEM Cam. What are the usual bugs to looks for?
Old Apr 30, 2004 | 11:41 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I'd start looking for vaccum leaks.. Cracked vac hoses/lines, disconnected lines, bad diaphram in your brake booster.. anything that uses vaccum.....
Old May 1, 2004 | 11:33 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Haven't met a third gen V6 that doesn't have a slightly erratic idle so far.....but under acceleration definitely indicates more than some minor glitch.
Any check engine codes? Does it kind of drop out on you or does it actually misfire or backfire or anything?
Old May 1, 2004 | 12:48 PM
89RsPower!'s Avatar
V6? I was assuming he was talking about the L98 he has listed under "Engine"
Old May 1, 2004 | 03:02 PM
Nixon1's Avatar
My fault....I usually browse the V6 section only...forgot I was in the general tech section.
Old May 1, 2004 | 05:28 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Is it in open or closed loop when the symptoms occur?
Old May 1, 2004 | 06:55 PM
Camin89Camaro's Avatar
Car: 89 Camaro
Engine: 305 TBI
Transmission: Th350
My RPMS used to dance around at idle or accleration I changed the wires and caps now its smooth as it can be
Prodigious
Oct 4, 2015 11:20 PM
IROCtometal
Sep 2, 2015 02:01 PM
someone972
Aug 30, 2015 12:52 AM
perZ
Aug 15, 2015 01:17 PM
Bradsaundry
Aug 12, 2015 12:34 AM
