hypothetical question about gear ratios
Old Mar 15, 2001 | 06:46 PM
cobrakiller1989's Avatar
Would it be less stressful, while flooring it, on a drivetrain if you have higher gears, say 3.73's as opposed to 2.73's. I was just thinking that it would be easier for everything to get moving since the gears are taller. I was just curious about this and was wondering if anyone knew.
Old Mar 15, 2001 | 06:54 PM
Blade's Avatar
I believe it's more stressful if you have 2:73 gears since it would harder to get the car moving... not as much "mechanical leverage" would be one way to put it.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
[This message has been edited by Blade (edited March 15, 2001).]
Old Mar 15, 2001 | 07:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Blade has it right, as far as the "torque loading" on the trans and driveshaft goes. On the other hand, with the higher gear, the RPMs would always be higher; so that part of the loading on things, like bearing and U-joint wear, would be higher. Plus, with the higher-ratio gears, the torque delivered to the axles would be higher by the ratio of the ratios to each other (¿huh?), which means the stress on them would be higher.
All in all, in my experience, the overall reliability is about the same, it just moves the failure point around.
ICON Motorsports
[This message has been edited by RB83L69 (edited March 15, 2001).]
Old Mar 15, 2001 | 07:02 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
thats how i look at it. because say you take off in a higher gear well with a manual many times the clutch will just slip till the car gets rolling.
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
