Failed emissions!!!!!!! Too much CO!!!!!!!
Old Mar 15, 2001 | 12:11 PM
FormulaGod's Avatar
Damn it, i was so close too. I failed CT emissions for too much CO (Carbon Monoxide)Enerything else i cleared fine.
Now does this mean im running too rich, or too lean?
I have an adjustable fuel pressure regulator, so i wanna play w/ that. Any suggestions?
"Restore decency in America. Ban rice!!"
Moderator at www.Lastgen.com check us out!!
Old Mar 15, 2001 | 01:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is too rich.
FP might help, might not. The ECM will tend to simply vary the duty cycle to make the O2 reading what it wants it to be, so it might not change it at all. Another quick & cheap thing to try would be a new O2 sensor.
ICON Motorsports
Old Mar 15, 2001 | 01:36 PM
Steve89GTA's Avatar
As posted in the 'TPI' section,
I had the same problem...failed first time with no AIR connected. I connected the Air Pump directly to the exhaust port that goes to the cat (no diverter) and I passed! Backfired a bit on the way there but it worked!!!
Old Mar 15, 2001 | 05:04 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Change out to a hotter plug, that should do it for you. To be on the safe side, add in the dry gas trick.
"Pray to God, but at the same time use your hands"
-Greek Proverb
Old Mar 15, 2001 | 07:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I failed CO with my van last month - 60 gr/mile against 55 required. Everything else was fine. Since this was the third time in 4 years I had trouble getting it through, and had done all the "other" stuff the 1st two times, this time I replaced the cat - nothing else done. Retested, CO went down to 12. HC & NOx went down as well.
Factory cat didn't have any catalyst left in it (no, it wasn't "gutted"). Small wonder it wouldn't pass.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
[This message has been edited by five7kid (edited March 15, 2001).]
Old Mar 15, 2001 | 09:56 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
<font face="Verdana, Arial" size="2">Originally posted by five7kid:
</font>
Well, more like flaked out or coated over. Catalyst is not used up in the process of catalyzation.
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
6998poncho
Sep 25, 2015 02:56 PM
