air pump removal on 82 firebird
Old Mar 15, 2001 | 09:58 PM
SUPER-SPORT-CHEVY's Avatar
Just bought an 82 firebird that has a broken line on the top of the smog pump the plastic crap can i take the whole air pump off with out the comp sending out a code? its the computer controlled carb so i think i can get away with it but want to be certian before i rip the pump off set a fire and dance naked around it?
Old Mar 16, 2001 | 12:08 AM
JETHROIROC's Avatar
I took mine out long ago without any trouble codes, so you should be fine. Just make sure you tighten some brass plugs into the manifolds as tight as you can get 'em and you shouldn't have any problems, that is, if you don't have emissions checks.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Ruger P95DC, hot wife, new oil filter,
thick rubber floormats, towels in the seats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Mar 16, 2001 | 09:20 AM
jobryan26's Avatar
LoL I like your sig. JETHROIROC
'87 Trans Am
305 TPI:
160 Degree Thermostat
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Old Mar 16, 2001 | 10:13 AM
Thx Jethroiroc.
I'll rip it off asap
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
mcquigg
Aug 13, 2015 02:26 PM
3rdgenparts
Aug 8, 2015 07:09 PM
