Strange Problem #2, idles from 750 to 1500
Old Mar 16, 2001 | 04:28 PM
gruveb's Avatar
Car: 1989 IROC-1
OK, if you're unfamiliar with the problem, read this https://www.thirdgen.org/messgboard/...ML/006748.html
Here's what I've found. Timing is correct, all cylinders seem to be firing just fine. I have fuel supply.
The car idles at a consistent 750 now when cold. As the car warms up, it jumps up to 1500. If I lower the idle screw, the idle will drop and the car will die.
There is also a lack of over all power, although I haven't driven the car.
What do I do?
Infested
May 22, 2018 11:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
db057
Aug 22, 2015 08:17 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
