What do I need to convert to rear disc brakes?
Old Mar 16, 2001 | 11:17 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
i have a 90 RS....what donor car am i lookin for....just a f body or will other 10 bolt cars work....for example what?
also....what parts do i need...caliper, rotor, brackets?? goin to pick a part tomorrow (50% off)
thanks guys
Rick
Old Mar 17, 2001 | 04:02 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I think your best bet would be to go with a rearend out of a thirdgen f-body. Since you'll have to replace the entire rearend, now would be a good time to get a posi and possibly a higher gear ratio. The highest factory available gear ratio that came in 10 bolt thirdgen fbodies was 3.42. That was only available with the manual tranny. You'll have to get all the obvious stuff for the breaks, like you already mentioned, but also remember that you'll need to get a different proportioning valve to use disk brakes. I'm not sure about the emergency brake, but you might need to swap some parts for it too. I think there's a tech article about how to do this in the FAQ.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
