camshaft
Old Mar 17, 2001 | 01:24 PM
robojr_2000's Avatar
camshaft
how hard is it to put a cam into an engine while it is still in the car? Is it possible to do this with never doing one before?
Old Mar 17, 2001 | 02:00 PM
ede's Avatar
ede
it can be done, and lot of peopel have done it. having the engine in the car wouldn't be my first choice, but if that's all i was doing i'd do it with the engien in.
ICON Motorsports
1st & 3rd
Old Mar 17, 2001 | 02:24 PM
SUPER-SPORT-CHEVY's Avatar
expect to work on it for a couple days.
You have to take off the carb, distributer"Make sure that roter points to no.1 driver side front" ,mainifold, valve covers, ac pump " you will have to drain the ac gas if you have ac", alternater, water pump,power stereing, smog pump, radiator, condenser, harmonic damper, timeing chain cover&gear, fuel pump "if not electric",and pull the hood latch assembly loose and tempararally bend it so the cam will slide out. its a pain in the butt and theres alot of wires that need to be disconected it took be a good 8 hours to change a cam in my 3rd gen fbod "including cleaning manifold ect".
Only took me 3 hours to change a cam in my 76 Pu "no ac or other crap". If you not an acomplished Mechanic, Count on 12 hours+ for the cam change.
Old Mar 17, 2001 | 05:24 PM
Dan87IROC-Z's Avatar
I did it, if you want me to, I will send you a detailed description on how to do it so you won't make the mistakes I did. Email me if you want me to write you on how to do it. My email is IROCZRacer87@aol.com
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
