Horsepower vs Torque
Old Mar 17, 2001 | 12:11 AM
Raymond 5.7 89 Formula's Avatar
Does anybody remember this article there was a link to it posted on the board many months ago. I had it saved in a folder that I lost. Would like to look at it again. Thanks for any info.
Old Mar 17, 2001 | 02:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
This one? http://www.calgarydragracing.ab.ca/t...andtorque.html
Old Mar 17, 2001 | 05:21 PM
Ovrclck350's Avatar
HP=(Torque X RPM)/5252
Sorry, I saw that on TV today. Had to put it SOMEWHERE.
Old Mar 17, 2001 | 05:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
HP is only a theoretical number since all dynos record torque. Using the above formula HP is calculated from the results. Torque is how much work the engine can do. HP is how fast the work can be done.
When calculating HP from dragstrip results, it's best to use MPH. ET relies too much on traction and can't give an accurate enough reading. Finish line MPH will remain the same if you have a good or poor 60 foot time.
Dragstrip HP formula is:
HP=weight X (mph/234)cubed
Lets say your 3500 pound car is trying for a 100 MPH club. How much HP do you need?
HP=3500 X (100/234)cubed
HP=3500 X 0.078
HP=273 rear wheel HP required to push a 3500 pound car 100 mph in the 1/4 mile.
Want a faster car in the 1/4 mile with that engine? Make the car lighter.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
