Is This Possible?
Old Mar 18, 2001 | 07:14 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Is This Possible?
Summit sells an item that you put on each header and can convert from open headers or exhuast w/muffler. I am getting 3" exhaust put on so I was thinking of getting that item. First question it says that you weld them behind each header, could on just be welded between the y-pipe and the intermediate pipe. And my last question how do you actually work this item. Do you have to get under the car and remove a slot or whatever, or is there a way that when I am rollin through a parking lot I can flip a switch and have open headers. I know this isn't legal just questions I want to know.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Old Mar 18, 2001 | 07:59 AM
ede's Avatar
ede
it's just a y sort of arrangement with one side open to the stock pipes and the other with a cover bolted to it, to go to open headers just unbolt the cover and the spent gas takes the path of least resistance out.
ICON Motorsports
1st & 3rd
