What kind of spark plugs should I run with canfield 195s?
Old May 5, 2004 | 04:07 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
My motor constantly seems like its fouling out plugs because it will only idle around 1,000 rpm for 30 seconds before it gradually dies, an the idle screws are adjusted right, and the power valve is not blown. It think its the plugs........I'm running autolite 3924's, what should I be running?? I'm also running a shot of nitrous so what plugs should I be running to go a heat range cooler? And when they say heat rang cooler................what exactly do they mean?? a heat range cooler than WHAT???
Old May 5, 2004 | 05:43 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Check with Jegs, I went from GM Iron #461s to AFR 195s and bought a new set of the same plugs I had been using before and after the head swap it would foul them and the motor had terrible throttle responce. I was dumbfounded...
I had a set of brodix Track 1s laying around, so I screwed in a plug. It was about 1/4" from even making it out of the threads and into the combustion chamber.
Here is what I found on spark plug heat ranges....
http://www.nagca.com/grandtech/sparkplugheat.htm
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
