exessive bearing wear
Old May 6, 2004 | 10:07 AM
ar_mcadams's Avatar
Car: 91 camaro
Transmission: auto 700r4
I have a 350 that was rebuilt and only has 5 k miles on it since the rebuild. It was bored 30 over and all the rods are origionl and so is the crank. When I took the motor apart before the rebuild the crank bearings looked fine for 100 k miles on the motor. The otherday I had to take the motor back apart and the (new) bearingd looked very bad. Some were wore all the way to the copper. The crank measured to be within specs, but the my question is would the 30 over pistons cause the balancing to be off enough to do this. The pistong and bearings were the only thing that was replaces and the rest is all origional. Correct breaking procedures were taken. thanks
Old May 6, 2004 | 10:08 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably the wrong oil... I'd guess too thick
Old May 6, 2004 | 10:51 AM
ar_mcadams's Avatar
Car: 91 camaro
I used 10w30. Same as when I did the breakin when the engine was brand new.
Old May 6, 2004 | 11:00 AM
ede's Avatar
ede
did you check your oil clearance when you assembled the engine? 30w dino oil is usually the recommended break in oil.
Bubbajones_ya
Oct 25, 2015 08:01 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
