Rotating Engine??
Old May 6, 2004 | 10:02 AM
85camaro350's Avatar
Car: 1985 Camaro Z28
Engine: 350 carb
Transmission: TH-700-R4
Rotating Engine??
I need to install my distributor on my 350 and i know that u have to get it to tdc and rotate engine....how are you guys rotating your engine? by the flywheel? or starting the car....thanks
Old May 6, 2004 | 10:06 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://store.summitracing.com/partde...rt=SUM%2DG1063
Old May 6, 2004 | 11:02 AM
ede's Avatar
ede
i've used the crank bolt, flywheel, and the starter all at one time or another
Old May 6, 2004 | 01:28 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I have used what RB has posted; that works just fine.
If the balancer is on the engine, i have used something like this:
I have both in my tool box and both work equally well. I prefer to use the first, however.
For getting TDC compression i use a starter interrupt switch and bump it over, then i manually bring it to TDC once i find the compression stroke.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
