86 iroc z
Old May 6, 2004 | 11:50 AM
three33three's Avatar
86 iroc z
86 iroc z
hello everyone
my brother just got a 86 camaro z28 tpi 5.0 auto
it came with flowmasters and 3in pipes cat back and thats all.
now my question is what little mods can i do to make it as fast as a stock ford mustang 5.0 with 225hp and 300lbs of tq,i was looking on the net and it says the my tpi 5.0 only has about 190hp and 285lbs of tq, how whould i be able to get to 225hp and 300lbs of tq?
Old May 6, 2004 | 12:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Lose weight
Nitrous
Old May 6, 2004 | 01:55 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Now add headers.
Old May 6, 2004 | 02:14 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Your gonna need headers, a high flow cat, 1.6 roller rockers(to give your cam a little more lift), and at least 3.42 gears to take a stock 5.0. Good Luck.
Old May 6, 2004 | 03:08 PM
i was looking for some t.p.i. runners, whould i get a big HP gain out of doing this?,of so about how much HP?
Old May 6, 2004 | 03:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably you'd end up with a HP loss from just changing the runners by themselves. You'd need to change the intake base and port the heads to get much out of that.
It's not real easy to take a stock 305 TPI motor in a 3400 lb car and run it against the brand F motor with its better designed FI manifold in a 3100 lb car. No magic bullet to fix the list of odds that are stacked against you. It's not like there's one simple little thing the factory just screwed completely up that's holding it back that you can just reach in and tweek.
Another thing you can do is work on traction since a stock Mousetank will spin the tires alot and not go anywhere, so you have the opportunity to lay a serious 60' spanking on one; and work on driver technique. And, once you get the traction issue dialed in, a torque converter can make an ENORMOUS difference to your leave.
Raw HP numbers by themselves won't tell you who's going to win the race.
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
