just a quick question
Old Mar 19, 2001 | 03:45 AM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
will a bad egr valve cause an erratic idle?
Old Mar 19, 2001 | 04:03 AM
The ODB's Avatar
definately
Old Mar 19, 2001 | 04:48 AM
bubbz89's Avatar
Car: 1990 RS
are they hard to replace?
Old Mar 19, 2001 | 09:01 AM
Beefy89's Avatar
Not too bad,more time consuming than hard.You need to remove the upper intake system to get at it.Mine through an egr code once,so I took the plenum off and sprayed a little top engine cleaner(I think GM says NOT to) up inside the egr valve and moved the diaphram up and down a few times,and hasn't thrown a code since.
We need Perry Mason
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
