car not idling!! step in and help
Old May 6, 2004 | 08:39 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
i jsut finished my swap to a 350 carbed and i cant get it to idle. everytime i start it, it fires right up and then shuts off in about 10 seconds. and thats when i pour gas in the carberater. should i tune it? regulater is feeding gas at 5.5 . is that enough? also if i tune it can someone give me directions on how to tune it or which way i turn the idle screw and how much?
Old May 6, 2004 | 09:36 PM
Nightrider350's Avatar
Car: 1988 Black Firebird
Engine: Chevy 350ci
Transmission: 700 R4
If you have fuel going to the carb. There is a little screw on the side that you have to adjust to position the throttle cable at the correct spot.
Old May 6, 2004 | 10:21 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
wut about the mixture screws? also my gas is about 4-5 months old. problem? i didnt put stabilizer in it
Old May 6, 2004 | 11:44 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
is the carb you are having troubles with the 600 cfm Edelbrock mentioned in your sig?
If so, is it the electric choke model or the manual choke model?
There are 2 screws on the front of the carbs main body. These control the idle mixture. Try fiddling with these. Also, you may want to adjust the float levels if the front screws dont solve it and the choke is fully functional.
And yes, bad gas may be part of the problem.
Old May 7, 2004 | 12:25 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
would my timing come into play with this?
and yes i have the manual choke model
its the edelbrock performer 1405 600 cfm model
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
