how to advance my timing
Old May 6, 2004 | 09:10 PM
hotshotcamaro's Avatar
Car: 89 camaro RS
i have read countless articles on the site, but i am kind of a dumass sometimes and don't pick up on things
so i have a 305 TBI
wondering what the exact procedure is to advance the timing on this car would be, and what your recomendations to timing are, i seem to hear 4 and 8 a lot
Old May 6, 2004 | 09:31 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
simple actually
well first thing you have to do is put a paper clip in the A and B terminals in the aldl (the plug in by your fuses). then disconnect a couple wires from your dist (I forget which ones). get your timing light and dist wrench out...ohh yeah, clean the timing tab up so you can read it and put a white mark on the line on your balancer, you will see what I'm talking about)...anyway loosen the hold down clamp on the dist so you can move it a little then point your light at the balancer and you will see where your timing is set at. I belive factory is 0*, you want to set it at between 4 and 8*, I personally have mine at about 4 1/2 but go to whatever it takes to get a nice idle.
I hope I didn't confuse you any and if I'm off on somthing I hope someone corrects me but if I am remembering correctly that should do it. good luck
out of curiosity where in WI are you?
Old May 6, 2004 | 10:32 PM
Car: 89 camaro RS
i'm from green bay, but i can easily be found in the green bay, oshkosh, and marinette areas
thanx for the info, i don't have to move the distributor at all do i, and is the timing light hook up or whateva, by the spark plug #1 and if so/ or not which side/part of the engine is it?
i found the ESC wire to disconnect
and i have to get undre the car right, cause it is in a small garage right now, so that prob. why i can't find most of the stuff i need to
Old May 6, 2004 | 10:50 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
hey im from appleton.....anyways your right, the timing light has to be on cylinderone, or plug one. the wires that you should disconnect is the igniton wire at the distributer. and yes u have to move the distributer to time it. i think i have mine at 6 but like red90bird said. set at what will make ur car idle right.
Old May 6, 2004 | 10:56 PM
Car: 89 camaro RS
your from appleton huh, my team wants to try to get to appleton to get ourselves known down there better, we are basically outta GB, we are known real well around here
if you wanna check out our messageboards hit up
www.titan-racing.com
Old May 9, 2004 | 01:58 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
thatd be cool. i checked out that site and i didnt see ur car.
Amillionoh7
May 24, 2020 08:01 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
