What is this?
Old May 7, 2004 | 05:22 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
What is this?
Hey guys..I want to remove my passanger valve cover to change the gasket but this is in the way. I need to remove it. What is it and is there any danger it taking it off and then puting it back on?
Old May 7, 2004 | 05:47 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
It's the EGR valve. You can safely remove the two bolts holding it onto the manifold and take it off. Make sure you put all the gaskets back on the right way when you remount it though!
And don't run the car with it off
Old May 7, 2004 | 06:31 PM
thanks....is it okay to reuse the old gasket?
Old May 7, 2004 | 07:09 PM
ChallengeR's Avatar
Car: Trans Am 87
Engine: 305 soon to be 350
Transmission: 700R4 soon to be T5
You just need a Block off plate!!
Not joking depend what your gasket look like...if its half on the intake and half on the egr than put a new one...but if its all in 1 pieces its good...but...the best is to buy a new one for...approximatly 5 bucks!!
