SBC Head ID Using Plug Size
Old Mar 19, 2001 | 07:08 PM
69-er's Avatar
How reliable would it be to ID SBC heads as far as chamber size is concerened using the plug size as a reference? It looks like
the peanut plugs might be used on the late model 76 CC chambers and the 13/16" plugs would match up to the 64 cc chambers.
If this would work as a preliminary ID on a good percentage of heads, then it would be easier to find the size head I'm looking
for without first pulling the valve cover.
Larry
Old Mar 19, 2001 | 08:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No that won't work.
All heads (as far as what came on cars) up to about 73 or so used the washer seat; all heads since use the tapered seat. There may be a few stray OTC replacement parts that don't fit this rule but this is pretty much what you'll find in the boneyards.
So there are a few OK tapered-seat ones, and spme real garbage washer-seat ones (283 3-barrel, & 307, for instance). Plus, things like 305 heads with 58cc chambers use tapered-seat plugs.
ICON Motorsports
CRFred
Feb 7, 2016 11:39 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
NinjaNife
Aug 23, 2015 11:49 AM
knight72
Aug 10, 2015 09:32 PM
