TPI Runner bolts
Old Mar 19, 2001 | 10:08 PM
Wolfcoast's Avatar
TPI Runner bolts
Anyone know what size or where I can get the bolts that attach the runners to the plenum and intake?? I'm getting a TPI setup that's missing these bolts so I need to get some.
Thanx in advance.
Randy
84 Trans AM LG4, 700R4 T-tops
84 Z28 L69, 5 Spd, T-tops
"Don't sweat the petty things...Just pet the sweaty things"
Old Mar 19, 2001 | 10:12 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I believe they are 8mm. I got mine at Sears Hardware. Stainless steel ones for like 19 Cents a piece,
Old Mar 20, 2001 | 12:13 AM
shawn87gta's Avatar
Check a fastener supply place - they are metric, so take one of each length to properly match them. I think there are three different lengths, but I'm relying on memory (scary). Some of them thread thru the intake (not blind holes) so you could go a little longer at these particular locations. All of the runner-to-plenum bolts thread thru (I think - memory again).
Get socket head cap screws and a long ball-end allen wrench. These came with my SLP runners and they are the only way to fly. The ball-end allen allows for a pretty drastic angular engagement (like a socket swivel), which makes the bolts much easier to get to. I also replaced the TB bolts with socket head screws to get a consistent look.
Old May 19, 2009 | 01:07 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: TPI Runner bolts
The Runner Bolts are M8 with a 1.25 mm Pitch, and lengths vary depending on the application.
Old May 19, 2009 | 03:36 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I replaced all of mine with black allen head ones from Lowe's. It's been a year since I did it, and I don't remember the exact lengths I got. I do remember needing at least 2 different lengths though, seems like the inner runner-to-plenum bolts are a little longer if I remember correctly. You can also pick up a bolt set fairly cheap off ebay:
http://cgi.ebay.com/ebaymotors/124-p...3A1|240%3A1318
Old May 19, 2009 | 10:10 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
All the runner bolts are M8 x 1.25. You'll need three different lengths: 30mm, 45mm and 80mm. Sorry, but I don't have a count of how many of what length you'll need.
I'd recommend 18-8 stainless over black oxide. The black oxide ones will rust and they'll look pretty bad.
I bought the 30mm ones in a pack of 25. The 45mm and 80mm came in a pack of 10 each.
In general, beware of cheap bolt kits. Cheap stainless steel bolts are pretty soft and will twist apart pretty easily.
evilstuie
Jan 9, 2020 08:29 PM
tazs2000
Jul 15, 2017 08:44 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
