with or without rear crossmember????
Old May 9, 2004 | 01:28 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
what that does mean??? some f body dont have crossmember that old transmission???? because some part to order they ask me that question???? so what does it mean??
Old May 9, 2004 | 05:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Some crossmembers look like this one. Others don't have the extra piece mounted on the bushings. It doesn't really make a difference, but the computer says ask, so they ask.
Old May 9, 2004 | 05:52 PM
FOX-GTA_89's Avatar
ok but mine on my manual t-5 there is nothing on it just the plate
so it mean without rear cross member??? its for the competition engeneering sub frame connectors they ask this question if answer is yes its 475$ and if without its 141$ sooo...?
Old May 9, 2004 | 05:56 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
No you have it wrong. When they ask "with rear crossmember" they mean do you want the subframe kit, with it or not. The subframe connector kits are different. I think the one with the rear crossmember is for setting up a different type of suspension ie. 4-bar. This is not what you want, you want the cheap one.
Old May 11, 2004 | 02:34 PM
FOX-GTA_89's Avatar
the cheaper one is without rear crossmember
and the one with cross member is expensive...
part off ekeystone....when i gine information bellows.
firebird 1989/accessories/subframes connectors/comp.eng.moroso
Old May 11, 2004 | 04:41 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
What? Huh?
You want the cheap one. You do not want the rear crossmember.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
87iroctheo
Dec 4, 2016 11:47 AM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Elliswon
Aug 10, 2015 12:33 PM
