Will PN 8226 MSD Coil work??
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I was wondering if that or wich Coil will work best For My car in my Sig
What was your expierence with putting one in??
I'm getting a 6AL and want to replace anything that Might need it for 125,000 Miles Any other Ideas to replace while at it?
Hecubus
http://www.tweak3d.net/temp/z28.jpg
91-Z28 305 Tpi "G92" mods-- K$N/Foil/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/ 100-150 Nos Wet Plate System/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel & Oil Press Guage's
Hecubus
Car: 91 z82
Engine: 5.0
I belive it is
It's the only one for GM
I was just wondering how well it went in the stock position it looks like the exact same to me
Hecubus
Hecubus
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
MSD Coil PN 8226 is a direct replacement as you already know. I put one in my GTA and it bolted on with no problems. You have to drill out the rivets that attach the original coil to the bracket, then you can mount the new one to the bracket using the screws that come with it.
As far as other coils for use with the MSD 6AL,I am sure they would work OK. The Ignition Control Box comes with instructions on how to connect it to the 8226 (need adapter cable from MSD) or any other coil with screw connections.
If you decide to get the MSD 8226 then get the adapter cable also.
CYA, Ozman
[This message has been edited by Ozzy88GTA (edited March 20, 2001).]
CYA, Ozman
Car: 91 z82
Engine: 5.0
Thanks Ozzy exactly what I needed to know
Hecubus
Hecubus
9192camaro
16
Feb 3, 2019 12:21 AM
tartagliaz28
Aug 15, 2015 10:59 AM
92camaroJoe
Aug 13, 2015 06:07 AM
