Fan?
Old May 10, 2004 | 05:41 PM
snipcod's Avatar
Car: 1984 z28 Camaro
Fan?
Where dose the fan that is under the battier go to. Its just blowing air know where. It looks like the tube that goes with it is gone.
Old May 10, 2004 | 05:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There was a flexible duct going up by the alternator, then a formed rigid duct that took air underneath the air cleaner to blow on the carb. It clipped on the fuel line nut and had a clamp to the alternator bracket.
The idea was to keep the carb a little cooler while the engine was hot and not running to reduce vapor lock. The fan has its own thermal switch in the return heater hose (at least mine does).
Old Jun 30, 2008 | 05:20 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: Fan?
I want to make sure I have vapor lock straight. Since using a different carb (but very similar E4ME carb), when my car has really been driven and warmed up, then up to an hour or even two later it doesn't star. no click. nothing. did this several times during last month. battery checked good. added a blanket to protect the starter from heat but it almost did it again on Sunday. Is this vapor lock?
Old Jun 30, 2008 | 05:30 PM
five7kid's Avatar
No.
Old Jun 30, 2008 | 05:47 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: Fan?
No.
guess my starter hates heat then. Do you have a different idea?
Anyway, please help me out w/ a definition of vapor lock. thanks!
Old Jun 30, 2008 | 05:59 PM
five7kid's Avatar
Vapor lock http://en.wikipedia.org/wiki/Vapour_lock (obtained by a 10-sec Google search)
Starter problems have to do with the electrical properties of copper. The hotter it gets, the higher the electrical resistance. Since the starter operates on the electromagnet principle, where the magnetic field is a function of current, and higher resistance reduces the current for a given voltage (V = IR, or I = V/R where "I" = current), a hot starter will not work as well as a cool one.
Old Jun 30, 2008 | 06:10 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Re: Fan?
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
