LS1 SBC retrofit??
Old May 10, 2004 | 11:16 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
LS1 SBC retrofit??
Since the LS1 is such a proven performer, why doesn't someone come up with a head/ intake design that's on par with the LS1 design that would bolt on to the SBC?
Old May 10, 2004 | 11:20 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Because, the way the LS1 was designed is a WAY different animal than a regular SBC... its just way too complicated to make it work because absolutely everything is different.
Old May 10, 2004 | 11:28 PM
Car: '85 IROC
Engine: LB9
Seriously...?
The LS1 is a pushrod 90degree V8, it seems like it would be possible to design a set of heads that have a similar port design, and an intake to fit it that would have similar flow characteristics to the LS1 but would bolt on to the gen1 sbc.
I'm sure that if such a product came out it would be an instant success.
Old May 10, 2004 | 11:34 PM
Air_Adam's Avatar
Pushrods and the 90* angle is about all the 2 engines have in common though. The valvetrain geometry is likely different, the exhaust ports are different, meaning a whole new header design would be needed, the LS1 (I think) has a reverse flow cooling system that cools the heads before the block, opposite direction of a regular SBC. If you look at the intake ports on an LS1 head, you'll see they aren't anything like a SBC head... the ports are narrow and very tall, and spaced differently from a SBC, meaning that a whole new intake manifold design is needed as well.
Old May 10, 2004 | 11:51 PM
Car: '85 IROC
Engine: LB9
That's all true, but guys are buying special intakes to fit vortec heads, and don't seem to be complaining about it.
I know that the LS1 concept is radically different, but still it seems like it wouldn't be impossible.
Actually there's not much sense in debating it here, cause I surely don't have enough money to even begin playing around with the idea.
I'm just imagining that it might be possible to produce a set of heads for SBC that have those tall narrow intake ports and the other features of LS1 as well.
Old May 11, 2004 | 05:04 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Look where the head bolts are in the SBC. Look at the intake ports in relation to them.
Now go look at the same feature of the LS1.
Now figure out how to relocate the head bolt holes. Do that, and maybe you can do some good.
As far as the height of the ports, that's how racing heads get bigger intake ports. You can't make them any wider (well, not much anyway) and you can't lower them, so the only way to get bigger ports is to go up. But you can only go just so far before you run out of intake flange, and then you run into valve cover flange. If you move all of that up and out, then it becomes possible.
Hard to say whether it would be economical, or whether you'd be able to sell them for enough to make a profit.
Old May 11, 2004 | 08:48 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
its been done.
go look at a SB2.2
its chevys NASCAR race motor.... it has evenly spaced ports(like the LS1), a much lower valve angle (like the LS1), totally diffrent valvetrain geometry(like the LS1), requires a diffrent intake(like the LS1), ect...
unlike the LS1, since its not a mass production part, you pay real race part prices... meaning upwards of 12,000 for just the top end.. and thats just bolting it on without port work or anything.
but you do end up with a 800+hp N/A SBC
Old May 11, 2004 | 08:51 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
It would be far easier to fit a complete LS1 in the engine bay. That way you would also get the benefits of the better designed block as well.
Old May 11, 2004 | 09:50 AM
kevinc's Avatar
Car: 1982 Z28
Possible, yes. Practical, no.
How much do you suppose you'd have to pay for a set of 15deg heads, spiffy intake, crank and cam position sensors, ECM that can keep up with the extra inputs, distributorless ignition, etc.?
Production and support costs would make the LS1 swap cost look pretty favorable...
And if you don't believe it, just go price up what's there now....set of 18deg SBC heads, valvetrain, and an Accel DFI-7 system plus dual-sync distributor gets you close to LS1 technology, and they're in mass production. Get ready for sticker shock.
-Kevin
Old May 11, 2004 | 05:59 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
The LT1's are reverse cooled but LS1's aren't. From what I've read. I like the idea about the LS1 heads though.
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
