Will 76 305 heads fit 400????
Old May 11, 2004 | 02:07 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
I have a clean set of 76 305 heads and i wanted to put them on a 400 shortblock i got will they work together?
Old May 11, 2004 | 02:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
They will "fit". You need to drill the steam holes.
Whether they are a "good" fit, that's another question...
Old May 11, 2004 | 02:39 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
you mean because they arent the best flowing heads?
Old May 11, 2004 | 02:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I can think of few heads would flow worse.
Putting those on a 400 would give you a motor that you could put any cam, any carb, any intake, and any exhaust on; open the throttles wide open with the trans in neutral; and it probably wouldn't go over 4000 RPM. It would be a total pig to drive, and certainly not fast. Even worse than a stock 400, which is already pretty disgraceful. What you'd get is one of those motors like a stock TBI 305 car except even more so, where it will spin the tires all day long, but will barely crack 17 seconds in the 1320.
Just because something bolts up, doesn't mean it's a good idea to bolt it up that way.
Please don't waste a perfectly good block like that. Sell the block to somebody that will put it to better use, and buy yourself some better heads with the money.
Old May 11, 2004 | 08:33 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Ok could you recomend a better non aftermarket head? please i could use some suggestions.
Old May 11, 2004 | 08:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What pistons are in the 400?
If they're stock (dished), look for 64cc iron heads. The L98 heads (083) or double-humps such as 186, 492, 041, etc. work great on 400s. I can't tell you how many of them I've yanked the 882s and 624s off of and dropped 186s onto; it's astounding the difference that makes, even leaving the stock 2-barrel carb and intake.
Double-humps are getting harder to just fall into; but if you watch the classifieds on this site, you'll se 083s come up pretty often.
Old May 11, 2004 | 08:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
In fact, there's a couple of sets on there right now.
https://www.thirdgen.org/classifieds/
Old May 11, 2004 | 08:57 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Oh damn i was just looking at a set of 492 heads with 2.02 1.60 valves and 64cc chambers just wasnt sure about accessories bolting up?
Old May 11, 2004 | 09:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They'll bolt up.
Old May 12, 2004 | 05:58 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
One more question would 89 vette aluminum heads be a good idea?
Old May 13, 2004 | 10:13 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
I would agree with RBL83L69 on this one, there are better heads for the street...However, the local 1/4 mile roundy-round track has a set of "stock"rules, and racers being racers, they work to get around those rules. Currently the "hot setup" is a 400 SBC with 305 heads and a 350/350 cam. These engines run strong, and last a season of on the gas/off the gas use. So.. could you build this into a decent combination? I would say yes, especially within the context of a certain set of rules. But, since street guys have no specific set of rules, then there are better ways to go.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
