sensor tests ????
Old May 11, 2004 | 05:17 PM
darren_A's Avatar
Car: 1987 IROC Z28
Engine: 305 TPI and NOS
Transmission: 4 Speed Auto 700R4
sensor tests ????
Hello all, New here and already I am having problems.
I am looking for any tests to preform to test all of the sensors on a 1984 Z28 Camaro.
Questions are along these lines.
what is the proper readings for the Baro, map, TPS, metering jets,
O2 sensors with key on no run.
this is on a 84 z28 305 4 Barrel carb. 4 speed auto.
The problem is when starting it floods badly so I am thinking the baro sensor is bad but many people have tried working on this car and things are not in the best of shape.
So I would like to test all of the sensors just to be shure.
Thanks Darren A
Old May 11, 2004 | 06:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
The only "sensor" that causes flooding is the carb fuel bowl float.
You can get over-rich conditions from a choke that isn't going off, or an O2 sensor that doesn't give proper voltage when running, or a failed mixture control solenoid.
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Ironhead38
Sep 7, 2015 02:26 PM
Eric-86sc
Sep 7, 2015 02:10 PM
willyjoejr
Sep 3, 2015 09:26 AM
