motor mounts
Old May 11, 2004 | 04:29 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
motor mounts
i was thinking about putting solid mounts on my car but i was wondering would it just shake my car apart or acctuly help cause i have a 350 and i need to tranny mounts and motor mounts
Old May 11, 2004 | 04:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It doesn't help anything at all.
For a street car, not a real good idea, especially considering how much work it is to change them again when you figurre out that you shouldn't have done that.
Old May 11, 2004 | 04:42 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Its an excellent idea! In fact I can even sell you some slightly used ones! All sarcasm aside however, do yourself a favor and don't go with solid mounts. As far as shaking your car apart, with the current combo my car has enough shake to it to begin with, with solid mounts it was like driving in one of those massage chairs you see at the mall sometimes.. it also managed to loosen just about every part of the car that didnt have lock washers or locktite applied. Moral of my story take RB's advice.. he knows what hes talkin about.. if you're building a strip only car then maybe.. street car.. bad idea.
Old May 11, 2004 | 04:43 PM
89RsPower!'s Avatar
as far as the tranny mount goes though do yourself a favor and get a good poly mount, they work great and don't cost much at all.
Old May 11, 2004 | 04:55 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
thanks guys i'll just got get some new polly mount and be done with that thanks. i was jw my firend has a bmw 325i and he put solid one on and it made a big diff and i was gonna race in soem races around here like road caourse
Old May 11, 2004 | 07:12 PM
89RsPower!'s Avatar
poly motor mounts transfer a lot of vibration too, I run stock rubber mounts and a poly tranny mount since they are so adept at breaking on these cars.. might wanna rethink the poly motor mount idea if thats what you had in mind, just my .02 cents.. they can't be as bad as solids at least.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
