Whats causing my car to shake as I give it gas?
Old Mar 20, 2001 | 09:05 PM
RS'er's Avatar
Bad shaking as I let my clutch up and go in 1st...I havnt been able to drive te car around very much at all since I have no plates fo rit yet. Te entire car just shakes when i try to accelereate or go reverse.
Old Mar 20, 2001 | 11:04 PM
LottaBallsCamaro's Avatar
Does it do it if you pull off in second. if not, its something with your first gear, otherwise, your flwheel bolts might be loose
91 Camaro RS, 305 TBI
92 Lumina, 275,000mi and humping!
No mods yet...Hopefully:
Convert to dual-cat with headers and Borla catback exhaust.
350hp 305TBI I dont care what you say!!!!
RAM air hood & Z28 wing.
ABS system.
Positraction rearend with rear disc brakes.
Rebuilt front and rearend suspension with polygraphite bushings.
Strutbrace.
Rollbar.
Subframe connecters.
Old Mar 21, 2001 | 06:43 PM
Wayquick4u's Avatar
Possible motor mount broken
Old Mar 21, 2001 | 07:10 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
If the mounts are all good, sounds like clutch chatter.
How old is the clutch??
Maybe plug wires breaking down??
Is it a misfire??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
[This message has been edited by Engineboy (edited March 21, 2001).]
Ghettobird52
Jul 5, 2024 11:18 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
mustangman65_79
Sep 1, 2015 03:51 PM
