Air Compressor Problems!!!!
Old May 13, 2004 | 11:20 AM
GTA350VORTEC's Avatar
Car: Black on Black 1989 GTA
Engine: 5.7L Vortec TPi
Transmission: 6 Speed T56
Axle/Gears: 3:73
In my 1989 GTA 5.7 TPi......My Compressor will not come on unless I jumper the Low pressure cutoff switch. If the cutoff is not jumpered the compressor clutch will not engage and there is not 12v at the clutch engagement coil (not really sure what the propper name is, square two wire connector at front of compressor). When the cutoff switch is jumpered there is 12v at the clutch coil. What can I do to fix this problem so my A/C works properly? Do I need to replace the cut off switch? Please help....thanks.
Old May 13, 2004 | 12:36 PM
Axle/Gears: 3:73
Changed the Low pressure cut off switch on the accumulator....everything fine now. $13.50 from local store.
Old May 14, 2004 | 01:10 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
good deal
evilstuie
Apr 14, 2016 08:52 PM
dyeager535
Aug 28, 2015 08:10 AM
TheExaminer
Aug 25, 2015 07:34 PM
db057
Aug 22, 2015 08:17 PM
rh76camaro
Aug 15, 2015 12:48 PM
