couple guage ?'s
Old May 13, 2004 | 10:49 PM
hotshotcamaro's Avatar
Car: 89 camaro RS
couple guage ?'s
right now my car seems to ide at about 500 rpm, the oil pressue at idle sometimes is like 15 and sometimes is about 30-32, whenver i drive the oil pressue is anywhere from 30-50 depending on the rpm
do these numbers sound correct
Old May 14, 2004 | 06:03 AM
ede's Avatar
ede
factory gauge isn't known for being real accurate. 10psi per 1000rpm is acceptable
Old May 14, 2004 | 07:38 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If you are ever unsure about the readings that the stock gauge is giving, plug in a mechanical gauge and verify.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
