pistons and deck height
Old May 14, 2004 | 02:25 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
i'm trying to achieve a 10.5 - 10.8 c/r on my 383 stroker rebuild w/ 64cc heads. my question is, would it be better to go with a stock deck height and flattop pistons, or deck the block and use dish pistons? i know a tight quench is desireable but if i have to go with dished pistons that pretty much negates the quench effect, right? and of course i could save money at the machine shop by not having to pay for decking. which is the best way to go?
Old May 14, 2004 | 05:22 AM
ede's Avatar
ede
never done it but if i were building a preformance engine i'd go with zero deck and dished pistons along with small chamber heads. from what i've read and understand that makes the most efficent and effective combination as far as getting the fuel lit.
Old May 14, 2004 | 10:30 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Zero deck, 4.030 bore, -6cc SRP flat top pistons, 3.75" stroke, Felpro 1010 head gasket, 64cc chambers, calculated to 11:1 with a few different calculators I found on the web, and also in DD2000.
Quench is the height of the compressed head gasket at .039.
Tried 3 different cams. Needed some overlap to prevent detonation with anything less then 93 octane. The dynamic compression ratio was too high with the first two cams.
Now I'm using a cc306 camshaft and fuel milage has gone to crap but it's always ready to run.
Old May 14, 2004 | 11:05 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
68CC AFR 195 heads
KB 122 Flat top pistons
1003 Felpro head gasket
.005 in the hole
10.5 Compression
Comp XR276HR cam
Zero detonation on 93 octane.
I run a very agressive timing map as well.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
