oooooooooook........ Now it's not fixed
Old Mar 21, 2001 | 08:01 PM
MATEOZ28's Avatar
I got the car to run fine for about 1 hour after cleaning the IAC now the tachometer went out and it runs like **** again. Is there a way to check out where the problem is?
Old Mar 22, 2001 | 12:44 AM
MATEOZ28's Avatar
How can I tell how and where the tach is bad?
Old Mar 22, 2001 | 12:33 PM
MATEOZ28's Avatar
Anybody know?
Old Mar 22, 2001 | 01:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Unplug the tach from the distributor and see if that fixes the running problem... if it does, you have a bad tach, or tach filter; if not, you have a distributor-related problem that is affecting the tach's ability to see the pulses from the dist.
ICON Motorsports
Old Mar 22, 2001 | 01:29 PM
MATEOZ28's Avatar
Hey man, thanks for all the help before
Anyway Where would I disconnect the tach from a 1991?
There are 6 wires going into my distributer right? 2 of them are on one connection to the ignition module and the other four are on the other connection.
Old Mar 22, 2001 | 01:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
IIRC it connects to the coil... small white wire, big pink one is 12V supply to the system, you might have to remove the wire from the housing; check for good 12V at the big pink wire too while you're at it
ICON Motorsports
Bubbajones_ya
Oct 25, 2015 08:01 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
