Car wont start now! wtf
Old Mar 16, 2001 | 02:29 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
recently I have been having trouble with the car lacking power and running as if I had plug wires crossed, so I changed the dist cap, plugwires, spark plugs and fuel filter.
checked the distributor itself and the rotor, changed the ignition module and cleaned out the carb.
It seemed to be getting worse as i went through everything, now it wont even start, it turns over, catchs a few times but not enough get running, no matter where the timing is, it backfires through the carb as well.
could my coil have packed in? It's a fairly old one that I put back in when my other one burnt up.
any ideas? I'm getting very frustrated
Old Mar 16, 2001 | 02:39 PM
86Trans Am's Avatar
If everything is in it's right place i am just about sure it's your fuel pump, mine acted just as you are describing awhile back and then eventually died and wouldnt start, it was the fuel pump. But maybe not with a carb, just a thought.....
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
[This message has been edited by 86Trans Am (edited March 16, 2001).]
Old Mar 17, 2001 | 02:34 AM
82RECAROTA's Avatar
Old Mar 17, 2001 | 11:14 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Exhaust restriction?
Old Mar 18, 2001 | 08:09 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
<font face="Verdana, Arial" size="2">Originally posted by 82RECAROTA:
Sounds like your timing chain. When you crank it, with the air cleaner cover off, do you see gas squirting out of your carb? If so, I would definitely say it is the timing chain.</font>
Yes! I get raw gas squirting out the carb.
then again sometiems flame.
If the chain jumped a cog or two, couldnt that be made up for with timing adjust?
I found TDC according to my valvetrain, the balancer lines up, but the dist wasn't. I re-dropped the dist to point at #1 but still same prob!
chain can't be broke i watched all valves moving when finding TDC.
argh!
Old Mar 18, 2001 | 10:50 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If the timing chain jumped, you're SOL, repostioning the distributor only maike up for the loos in ignition timing, but the valve timing in relation to the piston, is still off.
Old Mar 19, 2001 | 12:03 AM
82RECAROTA's Avatar
Old Mar 19, 2001 | 08:56 AM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
Alright, I'll rip open the chain case and see what I find, thanks for the help guys!
Old Mar 22, 2001 | 01:31 AM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
**UPDATE**
I took of the cover today, only to find that the cam is indeed perfectly IN TIME!!
the chain is great condition as are the gears so that cannot be the problem.
so what the heck is going on!?!?
I've replaced every ignition component on the engine except for the distributor itself, which mechanically works fine.
what else is there??
help!!!
Old Mar 22, 2001 | 01:59 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
It may be the ignition module under the cap. When that thing is starting to go bad the dwell timing gets screwd up!
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 liter h/press. walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
Old Mar 22, 2001 | 11:40 AM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
<font face="Verdana, Arial" size="2">Originally posted by 86Tra/maro:
</font>
I changed that already
maybe the pickup coil is fryed?
that a rare thing to happen though
Old Mar 22, 2001 | 11:49 AM
gruveb's Avatar
Car: 1989 IROC-1
I am having very similar trouble, and have done many of the same things. I purchased a new coil, and it helped, but didn't fix it. I'm just as lost as you are. I have discovered a possible short in the altenator, which I am going to explore further today. Perhaps the the alt is going out and stealing the amps I need to get a strong spark?
I've changed everything else, which probably needed to be freshened up anyhow, but nothing has fixed it.
I'll let you know. Change the coil in the meantime, they're not too expensive.
Old Mar 22, 2001 | 02:08 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
I've changed the ignition coil and even the alternator, which has been losing charge for a while, I'm thinkin maybe its the pickup coil inside the distributor, thats right beside the command module?
my distributor is still the 82 factory distributor, something in there must be wore out...
its the only thing left
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 8, 2015 12:07 PM
L98GTA87
Aug 5, 2015 11:02 PM
