carb & factory TBI system
Old May 15, 2004 | 02:03 AM
WhiteGhost's Avatar
Car: 00 Trans Am
I will be converting from TBI to Carb. I am going to run a 1406 Edelbrock carb, and rpm intake with the center holes machined to work on my 87+ heads, with a vacumn advance distributor from jegs.. I read the tech article on this and have a question about the 3 port regulator suggested.. my question is why?? why do i need to get a three port?? I know i have 3 lines coming to the engine bay, one for the vapor canister that i have already removed and plugged the line.. another is your main feed to the TB unit and the third line is a return line running out of your TB to your fuel tank.. So why couldnt I just get rid of the return line and plug it close to the tank and simply install a single inlet/outlet regulator before the carb.. I know i would only need like 3-4psi of pressure at the carb so a regulator of some sort would be required.. but the 3 port is much more expensive than a single in/out style.. can someone explain to me if there would be any down falls to not running the 3 port and simply blocking the return line..
Thanks in advance
Old May 15, 2004 | 08:05 AM
ede's Avatar
ede
you need the return to bleed off excess fuel or to eliminate over pressure condition.
Old May 15, 2004 | 08:43 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
And that in tank pump would burn out in no time. It wasn't meant to be dead headed.
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
junkcltr
Aug 2, 2019 11:12 PM
pimp2303
Jul 27, 2017 02:03 PM
theurge
Aug 21, 2015 12:46 PM
