serpentine belt conversion problem?
Old Mar 22, 2001 | 09:38 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I in the process of converting my '82 Z28 to serpentine belt drive from an '88 5.7 Camaro. Everything went well, until I attempted to connect the heater hose to the water pump. Their is no place to connect the hose to the '88 water pump. What do I do with it? Do I need a special water pump? I'm doing the 1LE front brake upgrade as well.So I was hoping to drive the car on Sunday. Can anybody help? Do I need water pump part #????
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old Mar 22, 2001 | 10:39 PM
F-Messenger's Avatar
Hey there. Did you remember to get a reverse direction water pump. When you convert from v-belt to serp belt the water pumps change too. This may be the cause...?? Im not sure but might help. Good luck!
F-Messenger
Old Mar 22, 2001 | 10:40 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Did you try the hose that's designed to work on an 88? I'm pretty sure they both use the same radiator, so I don't see why a newer hose won't work.
Otherwise you might be able to get one of those flex hoses as a quick-fix.
Old Mar 23, 2001 | 04:11 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Yes,I have a reverse flow water pump. But it has no place to attach my heater hose. Like the pump I took off. Both radiator hoses match up fine. Do I need some different water pump? Thanx,ANDYZ28
Old Mar 23, 2001 | 05:49 PM
ANDYZ28's Avatar
Car: 1982 Z-28
My friend Bill Moates at Heritage Chevrolet found the answer. I need the water pump for an '88 Chevy 1500 pickup w/305. It has the extra heater hose fitting. Thanx,Guys
Old Mar 23, 2001 | 07:55 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
When GM went to the serpentine system, they ran the heater hose to the radiator instead. You MAY have a plugged hole in the radiator to use. Otherwise if you did buy a waterpump for a serpentine F-body(88-92) there is a hole thats plugged, you could use that hole if needed, just buy a fitting.
I converted mine to serpentine, I ended up buying a new parts store radiator because it is the neatest way to go.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Jan 10, 2008 | 07:18 AM
85_SS's Avatar
Car: 1985 Monte Carlo SS
Engine: 5.7L
Transmission: WC T-5
Axle/Gears: 3.73:1
Re: serpentine belt conversion problem?
Old thread, but I have a question - was there any particular reason GM did this? Did all Camaros run the heater hose to the rad (and have the port on the pump capped)? The actual waterflow is the same isn't it? So why would they make this change?
I just bought a 90 Caprice waterpump for a serpentine swap on my 85 Monte Carlo, and it doesn't have the heater hose port. I will check when I get home, but I think my rad has an extra port for this. I am just wondering if I should get a Camaro pump so I can hood up the heater hose to the pump directly, or if I should just run it to the rad as factory serpentine setups did?
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
