1/4 times for 87 GTA?
Old Mar 22, 2001 | 09:39 AM
Zio's Avatar
Zio
Does anyone know what a stock 87 GTA with a 350 TPI will run in the 1/4 mile?
thanks
Tom
Old Mar 22, 2001 | 10:51 AM
Flfinn's Avatar
Car: GTA '88
Engine: 420 Dart SHP
~15.4s
-88 GTA 305TPI/T5, 3.45 posi, Crane cams 2032, Edelbrock TES #6872, 3" cat-back, ported+portmatched heads, base, plenum, multiangle valve job, no cat, no air, Haltech E6GM ECM. http://www.helsinki.fi/~kjilehto
Old Mar 22, 2001 | 11:01 AM
Beefy89's Avatar
You can find all kinds of info on GTAs at www.gtasourcepage.com It's a great resource.
We need Perry Mason
Old Mar 22, 2001 | 02:52 PM
Zio's Avatar
Zio
Thanks guys for the info. Is there a site like that for camaros or Iroc-z? Also am i correct in saying that GTAs and Irocs had the same engines and same horsepower rating?
Tom
Old Mar 22, 2001 | 05:28 PM
jcyoung's Avatar
Zio, the horsepower ratings between the two cars are different. The chevy products run a more efficent air induction system and were rated approximately 10 hp more for the both the v-8s. Hope this helps.
Old Mar 22, 2001 | 05:32 PM
Elite GTA's Avatar
These cars stock would run high 14s to low 15s.
1989 GTA Trans Am
Gunmetal Metallic, T-Tops
L98, 700R4, 3.27
Mustangs are just jealous...and mopars had nothing on the LS6 Chevelles.
Old Mar 22, 2001 | 07:02 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
your looking at high 14's low 15's definitely
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 22, 2001 | 08:47 PM
20-psi's Avatar
I had an 87 GTA that ran a best of 14.48 with just a new chip and timing, but it would usually run 14.80's. Traded this car for a TTA and went 2 seconds faster.
Pete
Old Mar 23, 2001 | 01:11 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Are the 350TPI motors that slow stock?
I have an LG4 motor with a new carb and intake and I ran a best of 14.94.
Car runs easily in the low 15's and high 14's. And I had 155-165hp stock!!!
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Old Mar 23, 2001 | 06:07 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
87 IROC-Z28 350 TPI: 225HP and 330TQ
87 GTA 350 TPI: 210HP and 315TQ
Stock 87 GTA 350 TPI's usually ran about 14.5-14.6. A stock 87 IROC-Z 350 TPI will usually run about 14.2-14.4, because it doesn't weigh as much as the GTA, and the Camaro has a better air intake design. The GTA's 0-60 times aren't as fast also, usually a 6.4-6.5, and the IROC-Z usually a 6.2.
Looking For:
87 IROC-Z28 350 TPI: The car I want.
84 TRANS AM 305 H.O.: Another car that would be OK to own while I look for the IROC-Z!!
[This message has been edited by IROCZTWENTYGR8 (edited March 23, 2001).]
Old Mar 23, 2001 | 12:41 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I think you're a little optomistic on the times for 87 L98's. They had the smallest cam. From what I've seen, 87's are good for 14.8's to 15.2's. 88-89 with single cats are high 14's, and 89-92 with dual cats are mid 14's.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 23, 2001 | 10:44 PM
Administrator
I will have to disagree with u on this 91Z. I have seen test results for them that fast, given a good track with more than average conditions, a car with those #'s should be able to run that. Here are the cam differences:
350 TPI Engines
87: 202/207(duration) .404"/.415"(lift)and 114.5(lobe)
88-89: 207/213(duration) .415"/.430"(lift)and 117(lobe)
90-92: 202/207(duration) .413"/.428"(lift) and 114.5(lobe)
Looking For:
89GTAOz
May 16, 2020 09:31 AM
evilstuie
Jan 9, 2020 08:29 PM
The_Phoenix
Feb 4, 2016 07:10 AM
gta90
Sep 15, 2015 04:00 PM
Street Lethal
Aug 14, 2015 08:25 PM
