Car wont start, please help!!!!!!
Old May 17, 2004 | 07:21 PM
85camaro350's Avatar
Car: 1985 Camaro Z28
Engine: 350 carb
Transmission: TH-700-R4
Ok, i have a 350 carbed engine and it caught a carb fire last august, just getttin everything together to make it run again and it cranks but wont turn over. I have a new distributor, carb, wiring harness and such and finally got it all together and it wont start. I am getting fuel in the carb at 6.5 psi, and spark from the distributor. yes i did put the distributor in the right way with TDC and all that. i am stumped, oh and i also have a electric fuel pump up by the engine.
Old May 17, 2004 | 09:26 PM
black & gold's Avatar
Car: 84 T/A black & gold WS6
Engine: 5.0
Transmission: t5 5 speed
Are you SHURE the distributor is not 180 out? and you have spark at the plugs right. Check things over you have missed something. Spark,fuel,compression = running engine, good luck
Old May 17, 2004 | 09:34 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Did you install the timing gears aligned in the dot-to-dot setup? If so, flip the distributor 180° and try again.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
