my heater motor only blows out my window defroster, WTF?
Old Mar 24, 2001 | 09:38 AM
chris1roc's Avatar
I turned on my heat yesterday and it only blows out the window defroster. It does this with the AC also. What's wrong?
88 iroc
LB9 305 tpi
k&N, flowmaster, ADS chip
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Old Mar 24, 2001 | 10:31 AM
82camaro's Avatar
Car: 82 camaro SC
The window defroster is the 'default', when the controls aren't working. Pull the control unit out, check the connections, check for vacuum from the engine compartment. If it's connected good and has vacuum from the engine compartment(the engine needs to be running), then the control is probably bad. If you don't have vacuum at the control, check under the hood for a broken or unconnected vacuum line.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
TheExaminer
Aug 26, 2015 04:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
