what are the best stock heads for 305?
Old May 18, 2004 | 04:15 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
I was wondering how the stock 305 heads compared. I have a like new set of heads off a 84 L69 and was wondering if any of the other castings were better. Are the heads on my 86 tpi 305 any different? Just currious.
Old May 18, 2004 | 04:16 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Your 416 heads are about the best 305 heads going. But the 081 center-bolt VC are about the same.
Old May 18, 2004 | 04:22 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Yes I agree that the 081 castings are the best. TPI/87 L69 heads.
Old May 18, 2004 | 04:46 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
so 416 is the casting # for the 84 l69 motor? I guess I have the best of the worst then! lol just kidding. Somehow I wind up with a lot of 305 parts, i wish I could find free or cheap 350 parts instead.
Old May 18, 2004 | 05:44 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
113 heads
Old May 18, 2004 | 06:01 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
113, what engine where they on? the best heads would flow the most, big valves and smaller unshrouded combustion chambers. I thought the L69 heads were the probably best but have not seen all the other ones available to know for sure.
Old May 18, 2004 | 06:13 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
the 84 L69 has 416 heads. Port them up and add some 1.94" and 1.6" valves and you will be set.
Old May 18, 2004 | 09:44 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
I might have considered bigger valves if they didnt already have a new 3 way cut valve seat. I stumbled across these heads with new valves and valve guides for 50$, for that price I was not sure about them but the machine shop I took them to told me they were like the best gm 305 heads. I spent $150 extra for the valve job, springs and to have them milled a little. Hearing the same second opinion from you makes me feel better.
Old May 18, 2004 | 09:53 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
IIRC 113 is the vette AL head.
Old May 18, 2004 | 10:08 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
416s and 081s are the exact same head, except the latter has centre bolt valve covers.
601s also came on L69s and are perhaps a tad better better flow-wise.
All of them port and polish up excellently. Add 1.94" intake valves and you have a very good set of street performance heads for a 305 or a 350.
Follow the link at the endx of my sig.
Old May 19, 2004 | 10:14 AM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
Vortec 305s. Same thing as the L31 vortecs except with a smaller chamber (58cc) and smaller intake valve. Port design and chamber shape are the same as the 350 version.
After that my vote would go for 601's closely followed by 416s.
My 601s flow 220cfm on the intake(@ 28 in/h20 and .425" lift and 175 on the exhaust(@28 in/h20 and .445" lift). That is a near stock head, just undercut swirl polished stainless valves, gasket match, and a little bowl work.
Old May 20, 2004 | 08:08 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Axle/Gears: 3.23 and 3.27 posi
What heads are on an LO3? How do they compare (if they are different than what has already been dicussed?)
Old May 20, 2004 | 08:48 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
freak.....
bout the only thing the tbi heads are good for are to practice porting on before you trash a good set of 416's or 081's
check with dewey on where to find 416 heads
Old May 21, 2004 | 10:27 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
How bad are the heads on a Lb9 from 1988??
Old May 21, 2004 | 05:28 PM
RSFreak's Avatar
Originally posted by robertg
freak.....
Its all good, I'm going with a set of 350 heads.
Old May 21, 2004 | 05:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
"350 heads" are no guarantee of anything decent. In fact most of them are garbage too.
The heads on a LB9 are the aforementioned 416s in 85 and 86, and 081s from 87-up.
Old May 21, 2004 | 09:11 PM
RSFreak's Avatar
You're right, but they are free and right now I just need my car back on the road.
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
