Spark blowout on an NA motor?
Old May 18, 2004 | 04:18 PM
StealthElephant's Avatar
Car: 87' Iroc
Is it possible I'm getting spark blowout of a 10.7:1 350 motor?
My exhaust has always smelled pig rich at idle, no matter how much I messed with the idle screws.
I took the car to 4000RPM the other day and some guys from work told me I was blowing black smoke the entire time.
I've been having trouble getting the car to get good gas milage....so maybe it's just an ignition problem. Everything is brand new, from the coil, to the distributor, to the moroso 8mm wires. I'm running the R42LTS Delco plug for Vortec heads. Someone suggested I move up to a hotter plug for a better burn.
Old May 18, 2004 | 04:26 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I am guessing you have a huge carb for a 350 like a 750 with the stock jetting. Pull some jets out of it and lean it out some. Also make sure the timing is right. You should not get leaks out of the spark plugs and I don't think that changing to a different plug will help you.
Old May 18, 2004 | 04:54 PM
Car: 87' Iroc
My sig has my motor buildup. It's a 670 Holley Street Avenger. I believe is has 68/72 jets.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
