emissions elimination
Old May 18, 2004 | 09:17 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
how much would fuel economy suffer from the elimination of all the emissions stuff?
Old May 18, 2004 | 09:26 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
If done right, minimal, but why bother? In many cases the emissions stuff helps and rarely hurts performance if you upkeep it. The EGR system is a prime example of this.
Not to metion that tampering with the system is a federal offense.
Old May 19, 2004 | 10:08 AM
Dingley's Avatar
Engine: LG4 305
the only reason i ask is because i might be attempting an engine swap, and i want to knwo if i should hook up all the emissions equipment again
Old May 20, 2004 | 06:04 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
good call on that one... the egr valve lowers combustion temperatures signifigantly....you should connect it all up. as when you have to pass smog it will be a pain in the ***....not to mention the engine was designed and computer was designed to have the systems running....your car will run like crap if its not all together...
Pac J
May 17, 2020 10:44 AM
racereese
Oct 3, 2015 03:46 PM
