fuel pump wires
Old May 18, 2004 | 09:32 PM
Duke901's Avatar
Car: 89 Formula
fuel pump wires
I'm going from tpi to carb, and i want to hook the fuel pump up to a toggle switch. I already took out all of the computer stuff and sensors. So my question is what color, and where are the power and ground wires for the pump.
Thank you
Old May 18, 2004 | 10:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The ground wire is black and grounds to the floor pan near the front of the drivers seat under the carpet. The power wire is tan/white and runs along the driver side door sill under the carpet to connector C100 on the driver side firewall under the dash. From there it goes to the ECM, oil sender/pressure switch, MAF power relay, and the Fuel pump relay
Old May 18, 2004 | 10:27 PM
Duke901's Avatar
Car: 89 Formula
So the power wire is tan, thats what i thought it was but i heard that the 85 had a different color then 86 and up. Also with my computer gone and no fuel pump relay, will my gas gauge still work.
Old Jan 17, 2006 | 09:42 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
I am trying to do exactly this. any more info? i have an 86 z28 tpi to carb...ryan
wheres the best place to make a splice to use a switch? as far as cutting into the wiring.
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
