LS1 head flow numbers for my 84TA
Old Mar 24, 2001 | 10:45 AM
Matt84TA
Guest
Posts: n/a
(I am planning on putting an LS1 I bought into my 84TA).
Did some work on my LS1 heads at the machine shop yesterday.
Charlie has a Superflow head flow tester and I got all numbers at 28" and 77 degrees.
Intake Numbers:
Lift 0.1
Before: 61
After: 62
Lift: 0.2
Before: 129
After: 141
Lift: 0.3
Before: 189
After: 207
Lift: 0.4
Before: 221
After: 245
Lift: 0.5
Before: 227
After: 261
Lift: 0.6
Before: 227
After: 268
Exhaust Numbers:
Lift: 0.1
Before: 53
After: 54
Lift: 0.2
Before: 101
After: 111
Lift: 0.3
Before: 137
After: 151
Lift: 0.4
Before: 165
After: 188
Lift: 0.5
Before: 179
After: 212
Lift: 0.6
Before: 188
After: 224
These are with stock valves.
I wanted to get some pics but Charlie's digital camera is a POS and won't work in a low light condition. Give me some feedback! I was pretty pleased with the results myself!
Old Mar 24, 2001 | 12:35 PM
Matt84TA
Guest
Posts: n/a
bump.
I'd really like some feedback on these numbers.
Old Mar 24, 2001 | 12:59 PM
Blade's Avatar
What kind of feedback ?? They look better because you ported the heads! lol
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Old Mar 24, 2001 | 01:09 PM
Matt84TA
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by Blade:
</font>
Just wanted to know if I did a good job or not
Old Mar 24, 2001 | 10:43 PM
R.O.B.'s Avatar
I'd say you did a hella good job!
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Old Mar 25, 2001 | 10:56 AM
Vader's Avatar
Matt,
It looks like you have the information you need to size the cam, and lifts much over 0.500" will be a waste. I would try to find something that has a fairly aggressive ramp, lift to about 0.500", and a lot of duration over 0.300". I know the choices for LS1 engines are a bit limited, but a little homework here can really pay off.
You shouldn't have an trouble with flow on those heads - nice work!
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
